Installing MacBook Pro 13" Unibody Mid 2009 Battery
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
  • Add Note x
  • x 115
Don't pay Apple to replace your worn out battery. Do it yourself!
Relevant Parts
Image #1
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the following 10 screws securing the lower case to the MacBook Pro 13" Unibody:
    • Seven 3 mm Phillips screws.
Image #1
Add Note Edit Step 2  ¶
  • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
Image #1
Add Note Edit Step 3 — Battery  ¶
  • Remove the following tri-wing screws securing the battery to the upper case:
    • One 5.5 mm tri-wing screw.
    • One 13.5 mm tri-wing screw.
Image #1
Add Note Edit Step 4  ¶
  • Use the flat end of a spudger to lift the battery connector up out of its socket on the logic board.
Image #1
Add Note Edit Step 5  ¶
  • Lift the battery out of the upper case.
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Tri-wing Y1 Screwdriver
$9.95 · 50+ In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 11 In stock
