Page 1 of 1
MacBook Pro 13" Unibody Late 2011 Upper Case Replacement
Replace the upper case in your Late 2011 MacBook Pro 13" Unibody.
- Author: Phillip Takahashi
- Difficulty: Difficult
Replacing the upper case requires the removal of nearly every component in your MacBook Pro. You will also need to transfer your old trackpad over to your new upper case.
Sections
- Lower Case 2 steps
- Battery 2 steps
- Fan 3 steps
- Logic Board 12 steps
- Upper Case 23 steps
- Upper Case Replacement 9 steps
Tools
Tools (continued)
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 5
Fan
Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
Edit
Step 15
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
Pull the display data cable straight out of its socket on the logic board.
Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
Edit
Step 35
Use a plastic opening tool or another thin prying object to carefully pry the right speaker up from the adhesive securing it to the upper case.
Start prying up from the edge of the right speaker nearest the display. Starting from the other side may damage one of the antennas.
Pry up along the edge of the right speaker until it is separated from the upper case.
Edit
Step 42
Grab the upper case with your right hand and rotate it slightly toward the top of the display so the upper display bracket clears the edge of the upper case.
Rotate the display slightly away from the upper case.
Lift the display up and away from the upper case, minding any brackets or cables that may get caught.
Upper case remains.
Edit
Step 46
In the following steps, you will be working on your new upper case.
Use a T6 Torx screwdriver to loosely install the 1.1 mm set screw included with your new upper case into its tapped hole near the middle of the trackpad opening on your new upper case.
Only tighten it about one turn for now.
Edit
Step 47
Carefully insert the cable from your old trackpad through its slot cut into your new upper case.
Use one hand to hold the trackpad cable in place as you insert the two retaining tabs on the outer edge of the trackpad under the lip on the upper case.
Pull the trackpad cable as you seat the trackpad into its void in your new upper case.
Edit
Step 49
While continually trying to click your trackpad, gently tighten the T6 Torx set screw until the clicks return to their factory "feel."
You can tell when the screw is tightened just right by the noise it makes when the trackpad clicks. If the set screw is too loose, the trackpad will have excessive play before it clicks. If it is too tight, the trackpad will click too easily and won't make the characteristic loud mouse clicking noise.
Edit
Step 51
Tighten the outer two screws along the inner edge of the trackpad and check the alignment of it on the outer side of the upper case.
If its alignment looks good, install the rest of the Phillips screws along the inner edge of the trackpad.
Before reassembling your machine, verify that the set screw is still installed in a position so the mouse will click correctly.
This guide has been completed 2 times.
Page 1 of 1
