Installing MacBook Pro 13" Unibody Late 2011 RAM
Upgrade the RAM in your Late 2011 MacBook Pro 13" Unibody.
  • Add Note x
  • x 4
Sections
Tools
first image
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the following ten screws:
    • Three 14.4 mm Phillips screws
    • Three 3.5 mm Phillips screws
    • Four 3.5 mm shouldered Phillips screws
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
  • Remove the lower case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3 — Battery  ¶
  • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
  • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket.
first image
Add Note Edit Step 4  ¶
  • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
first image
thumb image 1
thumb image 2
Add Note Edit Step 5 — RAM  ¶
  • Pull the two RAM retaining arms away from the center of the RAM chip.
  • The RAM chip should "pop" up slightly from its socket.
first image
Add Note Edit Step 6  ¶
  • Pull the RAM stick out of its socket.
  • Repeat this process to remove the second RAM chip.
For more information, check out the MacBook Pro 13" Unibody Late 2011 device page.
Did you successfully follow this guide?
This guide has been completed 4 times.
