Page 1 of 1
Installing MacBook Pro 13" Unibody Late 2011 Left Speaker
Replace a blown left speaker on your Late 2011 MacBook Pro 13" Unibody.
- Author: Phillip Takahashi
- Time required: 45 to 60 minutes
- Difficulty: Difficult
Use this guide to replace a blown-out left speaker.
Sections
- Lower Case 2 steps
- Battery 2 steps
- Fan 3 steps
- Logic Board 12 steps
- Left Speaker 4 steps
- View:
- Paginated
- Full width
Edit
Step 5
Fan
Use the edge of a spudger to gently pry the fan connector up and out of its socket on the logic board.
It is useful to twist the spudger axially from beneath the fan cable wires to release the connector.
The fan socket and the fan connector can be seen in the second and third pictures. Be careful not to break the plastic fan socket off the logic board as you use your spudger to lift the fan connector straight up and out of its socket. The layout of the logic board shown in the second picture may look slightly different than your machine but the fan socket is the same.
Edit
Step 15
Grab the plastic pull tab secured to the display data cable lock and rotate it toward the DC-In side of the computer.
Pull the display data cable straight out of its socket on the logic board.
Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
This guide has been completed 1 time.
Page 1 of 1
