Image #1 Image #2
Add Note Edit Step 17  ¶
  • Remove the following two screws:
    • One 8.6 mm Phillips screw
    • One 5.5 mm Phillips screw
  • Remove the display data cable retainer from the upper case.
Image #1
Add Note Edit Step 18  ¶
  • Use the tip of a spudger to gently peel the microphone off the adhesive securing it to the upper case.
Image #1
Add Note Edit Step 19  ¶
  • Minding the many connectors near its edges, lift the logic board from the end nearest the optical drive.
  • Without flexing the board, maneuver it out of the upper case, minding the flexible connection to the DC-In board that may get caught in the upper case.
  • Remove the logic board.
Image #1
Add Note Edit Step 20 — Left Speaker  ¶
  • De-route the microphone cable from its slot molded into the left speaker enclosure.
Image #1
Add Note Edit Step 21  ¶
  • Remove the small piece of black tape covering the left speaker connector.
Image #1
Add Note Edit Step 22  ¶
  • Use the flat end of a spudger to pry the left speaker connector up from its socket on the logic board.
  • Pry up from beneath the wires.
Image #1
Add Note Edit Step 23  ¶
  • Carefully pry the left speaker off the foam adhesive securing it to the logic board.
  • Remove the left speaker.
Image #1
Add Note Edit Step 24 — Logic Board Replacement  ¶
  • Remove the piece of black tape covering the microphone connector.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
T6 Torx Screwdriver
$4.95 · 50+ In stock
Phillips #00 Screwdriver
Phillips #1 Screwdriver
$4.95 · 27 In stock
Arctic Silver Thermal Paste
$8.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 13 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
