View profile
Order History
Logout
Model A1181 / 1.83 or 2.0 GHz Core Duo processor
$2.95 · 50+ in stock
$4.95 · 50+ in stock
$2.95 · 11 in stock
$29.95 · 9 in stock
$24.95 · 22 in stock
$7.95 · 16 in stock
$7.95 · 50+ in stock
$59.95 · 50+ in stock
$9.95 · 50+ in stock
« Previous
Next »
Page 2 of 10
Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
Remove the following 3 screws:
One 11 mm Phillips #00 in the middle of the case.
Two 14.5 mm Phillips #00.
If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
The shorter of the three screws goes in the middle.
Remove the following 3 screws from the rear wall of the battery compartment:
Two 3 mm Phillips #00.
One 4 mm Phillips #00 on the right side.
When reinstalling these screws, it may be helpful to push down on the lower case to line up the screw holes.
Next » « Previous
1024
