Edit
Step 33
Hold the display with one hand while removing the screws from the left hinge mount.
Remove the following 3 screws from the left hinge mount:
One 6 mm smaller diameter Phillips from the right side.
One 6 mm larger diameter Phillips from the middle.
One 10 mm Phillips from the left side.
Lift the left hinge mount out of the computer.
Edit
Step 35
Front Display Bezel
The following steps should be identical for both white and black MacBooks.
Use a thin plastic card to release the tabs holding the front display bezel to the display assembly. There are five tabs along the left side of the display bezel.
Don't use a card that cannot be replaced if damaged. The clips can be difficult to remove and the card can bend and break, rendering it useless.
Edit
Step 38
Lift up the front display bezel from the top and use your plastic card to free the tabs along the bottom edge of the display bezel.
Make sure that your card is between the metal frame around the LCD panel and the display bezel and not touching the LCD panel itself.
After freeing all holding tabs, lift the front display bezel away from the display assembly.
Edit
Step 39
Sometimes when removing the front display bezel, the retaining clips that should remain captive in the LCD brackets come out with the front display bezel. Follow this and the next step to transfer the clips back to the LCD bracket.
Use a metal spudger or another thin tool to carefully pry the gray plastic clips off the tabs molded into the front display bezel.
Be careful, as the clips are made of thin plastic and are inherently delicate.
Edit
Step 40
Insert the longer end of the retaining clip beneath the edge of its recess cut into the LCD bracket.
Use the edge of a metal spudger to push the shorter tab on the other side of the retaining clip into the recess cut into the LCD bracket.
The second picture shows the LCD bracket properly installed.
Page 5 of 8
