first image
Add Note Edit Step 25  ¶
  • Lift the right speaker out of its housing and set it to the side.
first image
Add Note Edit Step 26  ¶
  • Using a spudger, gently pry up the white plastic slot and slide the metal c-channel to the right and away from the display.
first image
Add Note Edit Step 27 — Display  ¶
  • Use a spudger to carefully disconnect the microphone cable from the logic board. You'll want to work from side to side, and slowly wiggle the connector out of its socket.
  • Pulling on this connector vertically will break the socket off the logic board. This connector should be removed horizontally by gently pulling the microphone cable toward the screen while working a spudger between the connector and the socket.
Next » « Previous
