Installing MacBook Core Duo Battery Connector
  • Author: iRobot
  • Difficulty: Moderate
  • Add Note x
  • x 7
Charges battery and connects battery to logic board.
Sections
Tools
first image
  • Use a coin to rotate the battery-locking screw 90 degrees clockwise.
first image
Add Note Edit Step 2  ¶
  • Lift the battery out of the computer.
first image
Add Note Edit Step 3 — Memory Cover  ¶
  • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
  • The screws are captive to the metal memory cover.
first image
Add Note Edit Step 4  ¶
  • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
first image
Add Note Edit Step 5 — Upper Case  ¶
  • Remove the following 3 screws:
    • One 11 mm Phillips #00 in the middle of the case.
    • Two 14.5 mm Phillips #00.
  • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
  • The shorter of the three screws goes in the middle.
first image
Add Note Edit Step 6  ¶
  • Remove the following 3 screws from the rear wall of the battery compartment:
    • Two 3 mm Phillips #00.
    • One 4 mm Phillips #00 on the right side.
  • When reinstalling these screws, it may be helpful to push down on the lower case to line up the screw holes.
first image
Add Note Edit Step 7  ¶
  • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
first image
Add Note Edit Step 8  ¶
  • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
first image
Add Note Edit Step 9  ¶
  • Remove the following 4 screws from the back of the computer:
    • Two 7 mm Philips on the far sides.
    • Two 10.5 mm Phillips toward the center.
    • Do not over-tighten these; you can cause the case to distort.
first image
Add Note Edit Step 10  ¶
  • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
  • It is not necessary to remove the similar screws on the other side of the computer.
first image
Add Note Edit Step 11  ¶
  • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
  • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
  • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
  • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
first image
Add Note Edit Step 12  ¶
  • While holding up the upper case, use a spudger to pry up the orange trackpad and keyboard cable from its connector.
  • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
first image
Add Note Edit Step 13 — Battery Connector  ¶
  • Remove the single Phillips screw near the battery connector.
first image
Add Note Edit Step 14  ¶
  • Remove the small black plastic spacer from the computer.
first image
Add Note Edit Step 15  ¶
  • Remove the two Phillips screws attaching the battery connector to the lower case.
first image
Add Note Edit Step 16  ¶
  • Use a spudger to carefully pry the battery connector up and disconnect it from the logic board.
For more information, check out the MacBook Core Duo device page.
Did you successfully follow this guide?
This guide has been completed 7 times.
