Installing MacBook Core 2 Duo Inverter
Replace a blown display inverter on your MacBook Core 2 Duo.
  • Add Note x
  • x 52
Screen have no backlight? Replace the inverter.
Sections
first image
  • Use a coin to rotate the battery-locking screw 90 degrees clockwise.
first image
Add Note Edit Step 2  ¶
  • Lift the battery out of the computer.
first image
Add Note Edit Step 3 — Memory Cover  ¶
  • Unscrew the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
  • The screws are captive to the metal memory cover so you cannot lose them.
first image
Add Note Edit Step 4  ¶
  • Rotate the L-shaped memory cover so it clears the battery compartment opening and lift it up and out of the computer.
first image
Add Note Edit Step 5 — Upper Case  ¶
  • Remove the following 3 screws:
    • One 11 mm Phillips#00 in the middle of the case. (Head: 5mm dia. x .75mm thick)
    • Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
  • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
  • The shorter of the three screws goes in the middle.
first image
Add Note Edit Step 6  ¶
  • Remove the following 3 screws from the rear wall of the battery compartment:
    • One 3 mm Phillips #0. (Head: 2.75 mm. dia.)
    • Two 4 mm Phillips #0 on the either side. (Head: 2.75mm dia.)
  • Take extra caution with these screws as they can strip easily.
first image
Add Note Edit Step 7  ¶
  • Remove the two Phillips screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
    • Two 6.25 mm Phillips #000. (Head: 4 mm. dia. x .5mm thick)
first image
Add Note Edit Step 8  ¶
  • Remove the four indicated Phillips screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
    • Four 3.25 mm Phillips #000. (Head: 4 mm. dia. x 4mm thick)
first image
Add Note Edit Step 9  ¶
  • Remove the following 4 screws from the back of the computer:
  • The longer screws go on the inside, shorter screws on the outside.
    • Two 11 mm Phillips #00, with Shank (2.2mm dia. x 2 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
    • Two 7.25 mm Phillips #00, with Shank (2mm dia. x 3.75 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
first image
Add Note Edit Step 10  ¶
  • Remove the two Phillips screws from the optical drive side of the computer.
    • Two 5.2 mm Phillips #00, with Shank (2.3mm dia. x 3.5 mm len.) (Head: 3.2 mm. dia. x .5mm thick)
  • It is not necessary to remove the similar screws on the other side of the computer.
first image
Add Note Edit Step 11  ¶
  • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
  • Starting near the display and working around to the front of the computer, pry up on the upper case. A plastic opening tool or a medium hard guitar pick may help you to do this.
  • The upper case is likely to stick at the connection above the optical drive. If this is the case, first free all other sides, then proceed to pull upward on the upper case from either side of the optical drive opening.
first image
Add Note Edit Step 12  ¶
  • While holding up the upper case, pull up the black tab of the silver cable away from its connector.
  • If there is no black tab, you can also use a spudger to gently pry the connector from its housing. This connector is tall, so be sure to pry straight up.
  • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
  • Upon reassembly, there are 4 grey plastic clips on the optical drive side of the keyboard. They must be installed in their slots for the keyboard to snap in properly.
first image
Add Note Edit Step 13 — Optical Drive  ¶
  • Grasp the white plastic tab attached to the hard drive and pull it to the left, removing the hard drive from the computer.
first image
Add Note Edit Step 14  ¶
  • Remove the two Phillips screws from the front edge of the optical drive.
    • Two 3.25 mm Phillips #000, (Head: 4 mm. dia. x .3 mm thick)
first image
Add Note Edit Step 15  ¶
  • Disconnect the orange optical drive ribbon cable from the logic board. This cable can also be disconnected by prying straight up using a spudger.
first image
Add Note Edit Step 16  ¶
  • Disconnect the newly revealed display data cable. If there is no pull-tab on the top of the connector, it may be helpful to use a spudger to disconnect this connector.
first image
Add Note Edit Step 17  ¶
  • Disconnect the (once again) newly-revealed hard drive cable.
first image
Add Note Edit Step 18  ¶
  • Peel up the foil tape between the fan and the optical drive. Lift the foil tape from the fan side, leaving it attached to the optical drive.
first image
Add Note Edit Step 19  ¶
  • Pull up the display data cable from along the edge of the optical drive to reveal a silver Phillips screw.
first image
Add Note Edit Step 20  ¶
  • Remove the 2 mm Phillips screw securing the optical drive.
  • The Bluetooth cable may be covering the screw; carefully push it aside before removing the screw.
first image
Add Note Edit Step 21  ¶
  • Lift the Bluetooth antenna board from the right side of the optical drive.
first image
Add Note Edit Step 22  ¶
  • Deroute the hard drive cable from along the front of the optical drive.
first image
Add Note Edit Step 23  ¶
  • Lift the front edge of the optical drive and slide it up and out of the computer.
first image
Add Note Edit Step 24 — C-Channel  ¶
    • Two 3 mm Phillips near the right speaker.
    • One 6 mm Phillips threaded through a hole in a plastic finger above the subwoofer.
  • Be careful not to over-tighten the screw above the subwoofer too tight or the plastic could crack.
  • Santa Rosa and Penryn MacBooks do not have a c-channel. If you are disassembling either of these models, remove only the 3 mm Phillips screw from the right speaker and skip step 26.
first image
Add Note Edit Step 25  ¶
  • Lift the right speaker out of its housing and set it to the side.
first image
Add Note Edit Step 26  ¶
  • If you have a Santa Rosa/Penryn model, skip this step.
  • Using a spudger, gently pry up the white plastic slot and slide the metal c-channel to the right and away from the display.
first image
Add Note Edit Step 27 — Display  ¶
  • Use a spudger to carefully disconnect the microphone cable from the logic board. You'll want to work from side to side, and slowly wiggle the connector out of its socket.
  • Pulling on this connector vertically will break the socket off the logic board. This connector should be removed horizontally by gently pulling the microphone cable toward the screen while working a spudger between the connector and the socket.
first image
Add Note Edit Step 28  ¶
  • Lift up on the black right speaker cable with one hand, and deroute the microphone cable from the silver metal clip just above the right RAM slot.
  • This metal clip may not be present in all models. Be sure that the cable is free from any hold downs around this area before proceeding.
first image
Add Note Edit Step 29  ¶
  • Remove the single 4.2 mm Phillips screw securing the ground loop in the right speaker cable and microphone cable to the metal framework.
first image
Add Note Edit Step 30  ¶
  • Deroute the microphone cable and the black display data cable from the tabs at the bottom of the subwoofer.
first image
Add Note Edit Step 31  ¶
  • Remove the single 3 mm Phillips screw securing the ground loop in the display data cable located just above the Bluetooth board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 32  ¶
  • Disconnect the three antenna cables from the Airport card. There may be a square foam piece over the logic board connector.
  • Disconnect the inverter cable from the socket by inserting the spudger between the right or left edge of the plug and the socket, and prying gently upward. (Do NOT pry the entire socket off the board... you must pull the plug from within the socket.) The inverter plug lifts vertically out of the socket. Do not pull it in the direction of the connecting wires or you will tear the socket off.
  • If you have a MacBook Core 2 Duo Santa Rosa/Penryn, there are only two antenna cables and the black inverter cable is in a different location.
first image
thumb image 1
thumb image 2
Add Note Edit Step 33  ¶
  • Remove the following 2 screws from the right hinge mount:
    • One 6 mm Phillips on the left side of the hinge mount.
    • One 10 mm Phillips on the right side of the hinge mount.
  • For Santa Rosa/Penryn models, see second picture and remove:
    • One 3 mm smalller diameter Phillips on the far left.
    • One 5.2 mm larger diameter 4.2 mm head Phillips in the middle.
    • One 10 mm Phillips from the far right.
  • Lift the right hinge mount with the small plastic piece out of the computer.
first image
Add Note Edit Step 34  ¶
  • Hold the display with one hand while removing the screws from the left hinge mount.
  • Remove the following 3 screws from the left hinge mount:
    • One 7.2 mm smaller diameter Phillips from the right side.
    • One 5.2 mm larger diameter Phillips from the middle.
    • One 10 mm Phillips from the left side.
  • Lift the left hinge mount with plastic piece out of the computer.
  • Check that the cables on the right are not trapped under other cables.
first image
Add Note Edit Step 35  ¶
  • Grasp the display assembly on either side, and lift it up and out of the computer.
first image
Add Note Edit Step 36 — Front Display Bezel  ¶
  • The following steps should be identical for both white and black MacBooks.
  • Use a thin plastic card to release the tabs holding the front display bezel to the display assembly. There are five tabs along the left side of the display bezel.
  • Don't use a card that cannot be replaced if damaged. The clips can be difficult to remove and the card can bend and break, rendering it useless.
first image
Add Note Edit Step 37  ¶
  • Continue to free the tabs along the the top edge of the display assembly.
  • Be careful when working near the iSight camera.
first image
Add Note Edit Step 38  ¶
  • Next, free the five tabs securing the display bezel on the right side.
first image
thumb image 1
thumb image 2
Add Note Edit Step 39  ¶
  • Lift up the front display bezel from the top and use your plastic card to free the tabs along the bottom edge of the display bezel.
  • Make sure that your card is between the metal frame around the LCD panel and the display bezel and not touching the LCD panel itself.
  • After freeing all holding tabs, lift the front display bezel away from the display assembly.
first image
thumb image 1
thumb image 2
Add Note Edit Step 40  ¶
  • Sometimes when removing the front display bezel, the retaining clips that should remain captive in the LCD brackets come out with the front display bezel. Follow this and the next step to transfer the clips back to the LCD bracket.
  • Use a metal spudger or another thin tool to carefully pry the gray plastic clips off the tabs molded into the front display bezel.
  • Be careful, as the clips are made of thin plastic and are inherently delicate.
first image
thumb image 1
thumb image 2
Add Note Edit Step 41  ¶
  • Insert the longer end of the retaining clip beneath the edge of its recess cut into the LCD bracket.
  • Use the edge of a metal spudger to push the shorter tab on the other side of the retaining clip into the recess cut into the LCD bracket.
  • The second picture shows the LCD bracket properly installed.
first image
Add Note Edit Step 42 — Clutch Cover  ¶
  • Remove the three 4.2 mm Phillips screws securing the clutch cover.
first image
Add Note Edit Step 43  ¶
  • While holding the display down with one hand, use your other hand to lift the clutch cover off the clutch hinges.
  • It may help to wiggle the clutch cover as you pull it up from the display.
first image
Add Note Edit Step 44  ¶
  • Lift up the right side of the clutch cover and guide the display data and iSight cables through the gap in the clutch cover.
  • Lift the clutch cover out of the display assembly.
  • During reassembly, make sure not to pinch the pink and white inverter cable when snapping the clutch cover back into place.
first image
thumb image 1
thumb image 2
Add Note Edit Step 45 — Inverter  ¶
  • Slightly lift the newly-revealed inverter board out of its housing and disconnect the black inverter cable from the left end of the board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 46  ¶
  • Disconnect the white inverter cable from the right end of the inverter board.
first image
Add Note Edit Step 47  ¶
  • Remove the inverter board from the display.
For more information, check out the MacBook Core 2 Duo device page.
Did you successfully follow this guide?
This guide has been completed 52 times.
