Installing MacBook Core 2 Duo Dual Hard Drive
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Use this guide to install a second hard drive in place of the optical drive.
- Author: Jake Devincenzi
- Difficulty: Moderate
There are many benefits to adding a second hard drive to your laptop such as improved speeds, greater storage space, and less heartache when installing new software. Use this guide to install one using our optical bay hard drive enclosure.
Sections
- Battery 2 steps
- Memory Cover 2 steps
- Upper Case 8 steps
- Optical Drive 11 steps
- Optical Drive Cable 2 steps
- Optical Drive Replacement 5 steps
- Dual Hard Drive 3 steps
- View:
- Single page
Edit
Step 5
Upper Case
Remove the following 3 screws:
One 11 mm Phillips#00 in the middle of the case. (Head: 5mm dia. x .75mm thick)
Two 14.5 mm Phillips #00 (Head: 5mm dia. x .75mm thick)
If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
The shorter of the three screws goes in the middle.
Page 1 of 5
