first image
Add Note Edit Step 4  ¶
  • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
first image
Add Note Edit Step 5  ¶
  • Lift the battery out of the Air.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6 — Hard Drive  ¶
  • Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab.
  • Pull the audio out ribbon cable off the adhesive securing it to the upper case.
  • Use a spudger to pry the audio out ribbon cable connector board off the hard drive bracket.
Next » « Previous
