Installing MacBook Air Models A1237 and A1304 Port Hatch Assembly
  • Add Note x
Replace your port hatch assembly to fix issues with the headphone jack and/or the USB/Micro-DVI ports.
Sections
Tools
first image
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the following 10 screws securing the lower case to the Air:
    • Six 2.8 mm Phillips screws.
    • Two 3.8 mm Phillips screws.
    • Two 5.4 mm Phillips screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
first image
Add Note Edit Step 3 — Battery  ¶
  • Disconnect the battery connector by pulling it straight out of its socket.
first image
Add Note Edit Step 4  ¶
  • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
first image
Add Note Edit Step 5  ¶
  • Lift the battery out of the Air.
first image
Add Note Edit Step 6 — Speaker  ¶
  • Remove the following two screws securing the speaker assembly to the upper case.
    • One 3 mm Phillips.
    • One 5.8 mm Phillips.
first image
thumb image 1
thumb image 2
Add Note Edit Step 7  ¶
  • Use a spudger to lift the audio-out connector board off the adhesive that secures it to the hard drive bracket.
  • Disconnect the audio out connector from its socket.
first image
thumb image 1
thumb image 2
Add Note Edit Step 8  ¶
  • Rotate the speaker assembly toward the center of the Air.
  • Use a spudger to pry the speaker cable connector up off the audio board.
first image
thumb image 1
thumb image 2
Add Note Edit Step 9 — Port Hatch Assembly  ¶
  • Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab.
  • If necessary, pull the audio out ribbon cable off the adhesive securing it to the upper case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 10  ¶
  • Remove the four 3.2 mm Phillips screws securing the port hatch assembly to the upper case.
  • Lift the port hatch assembly out of the upper case.
For more information, check out the MacBook Air Models A1237 and A1304 device page.
Did you successfully follow this guide?
This guide has been completed 2 times.
