Page 1 of 1
Installing MacBook Air Models A1237 and A1304 Fan
- Author: Walter Galan
- Difficulty: Moderate
Replacing a defective fan is pretty easy and will keep your laptop running cool.
Sections
- Lower Case 2 steps
- Battery 3 steps
- Hard Drive 6 steps
- Heat Sink 6 steps
- Fan 3 steps
Tools
Relevant parts
- View:
- Paginated
- Full width
Edit Step 6
Hard Drive
Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab.
Pull the audio out ribbon cable off the adhesive securing it to the upper case.
Use a spudger to pry the audio out ribbon cable connector board off the hard drive bracket.
Edit Step 14 ¶
If you have the original version of the MacBook Air (A1237), refer to picture 1. Remove the following screws securing the heat sink to the logic board:
One 5.9 mm Phillips screw.
Two 1.9 mm Phillips screws.
One 1.9 mm Phillips screw.
If you have the A1304 version of MacBook Air, refer to picture 2. Remove the following screws securing the heat sink to the logic board:
One 5.0 mm Phillips screw
Five 1.9 mm Philips screws.
One 2.5 mm Phillips screw.
Edit Step 17 ¶
Lift the heat sink up off the logic board.
Be mindful of the microphone cable when lifting the heat sink, as it can get tangled on the top edge of the fan.
When you mount the heat sink back onto the logic board, be sure to apply a new layer of thermal paste. We have a guide that makes replacing the thermal paste easy.
Edit Step 18
Fan
If you have the A1304 version of MacBook Air, the fan is a separate component. The following steps therefore do not apply to your model. Simply detach the microphone cable from where it is adhered to the fan, and lift the fan out from the machine at this point.
Remove the four 2.5 mm Phillips screws securing the fan to the heat sink assembly.
This guide has been completed 14 times.
Page 1 of 1
