Image #1 Image #2
Add Note Edit Step 9 — Audio Cable  ¶
  • Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab.
  • If necessary, pull the audio out ribbon cable off the adhesive securing it to the upper case.
Image #1
Add Note Edit Step 10  ¶
  • Use the pointed end of a spudger to de-route the microphone cable from the hard drive bracket.
Image #1
Add Note Edit Step 11  ¶
  • Remove the following screws securing the hard drive to the upper case:
    • Two 3.9 mm Phillips screws.
    • One 4.7 mm Phillips screw.
Image #1
Add Note Edit Step 12  ¶
  • Use the tip of a spudger to remove the cosmetic screw cover to reveal the last remaining screw securing the hard drive.
Image #1
Add Note Edit Step 13  ¶
  • Remove the 4.7 mm Phillips screw securing the hard drive to the upper case.
Image #1 Image #2
Add Note Edit Step 14  ¶
  • Lift the hard drive slightly and use a spudger to pry the audio cable connector up off the logic board.
  • Peel the audio cable off the adhesive securing it to the upper case.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Related Products
MacBook Air (Original) Audio Cable
$29.95 · 12 In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 11 In stock
