Installing MacBook Air Models A1237 and A1304 AirPort/Bluetooth Bracket
  • Add Note x
Replace the black plastic bracket holding your AirPort/Bluetooth board to the upper case.
first image
Add Note Edit Step 1 — Lower Case  ¶
  • Remove the following 10 screws securing the lower case to the Air:
    • Six 2.8 mm Phillips screws.
    • Two 3.8 mm Phillips screws.
    • Two 5.4 mm Phillips screws.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
first image
Add Note Edit Step 3 — Battery  ¶
  • Disconnect the battery connector by pulling it straight out of its socket.
first image
Add Note Edit Step 4  ¶
  • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
first image
Add Note Edit Step 5  ¶
  • Lift the battery out of the Air.
first image
Add Note Edit Step 6 — AirPort/Bluetooth Bracket  ¶
  • Remove the two Phillips screws securing the AirPort/Bluetooth bracket to the upper case.
first image
Add Note Edit Step 7  ¶
  • Lift the AirPort/Bluetooth bracket out of the upper case.
For more information, check out the MacBook Air Models A1237 and A1304 device page.
Did you successfully follow this guide?
This guide has been completed 1 time.
Required Tools
Spudger
$2.95 · 50+ in stock
Phillips #00 Screwdriver
$4.95 · 50+ in stock
Related Products
Recommended Tools
Home Tech Toolkit
$24.95 · 22 in stock
Sorting Tray
$7.95 · 16 in stock
Anti-Static Wrist Strap
$7.95 · 50+ in stock
Pro Tech Base Toolkit
$59.95 · 50+ in stock
Thirsty Bag
$9.95 · 50+ in stock
