Installing MacBook Air 13" Late 2010 Upper Case Replacement
Replace the upper case on your MacBook Air 13" Late 2010.
  • Add Note x
  • x 4
Use this guide to replace the upper case.
Sections
first image
Add Note Edit Step 1 — Lower Case  ¶
  • Before proceeding, close your computer and lay it on a soft surface top-side down.
  • Remove the following ten screws:
    • Two 9 mm 5-point Pentalobe screws
    • Eight 2.6 mm 5-point Pentalobe screws
  • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
first image
Add Note Edit Step 2  ¶
  • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
first image
Add Note Edit Step 3 — Battery  ¶
  • For precautionary purposes, we advise that you disconnect the battery connector from the logic board to avoid any electrical discharge. This step is optional and is not required.
  • Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
  • Do not lift upward on the connector as you disconnect it.
Next » « Previous
