Installing MacBook Air 11" Mid 2011 Solid-State Drive
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Replace the solid state hard drive on your Mid 2011 MacBook Air 11".
- Author: Walter Galan
- Difficulty: Moderate
Use this guide to replace a burned-out solid state hard drive.
- View:
- Single page
Edit
Step 1
Lower Case
Before proceeding, close your computer and lay it on a soft surface top-side down.
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
Edit
Step 3
Battery
In this step you will disconnect the battery to help avoid shorting out any components during service.
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Edit
Step 5
Use a spudger to help lift the free end of the SSD just enough to grab it with your other hand.
Do not lift the end of the SSD excessively.
Pull the drive straight out of its socket and remove it from the logic board.
When reinstalling the SSD, be sure it is properly seated before reinstalling its retaining screw.
Page 1 of 1
