Installing MacBook Air 11" Mid 2011 Microphone
Replace a blown-out microphone in your Mid 2011 MacBook Air 11".
Screaming at your MacBook Air might not hurt its feelings, but it could go deaf. Use this guide to replace a blown-out microphone.
Image #1
Add Note Edit Step 1 — Lower Case  ¶
  • Before proceeding, shut down and close your computer. Lay it on a soft surface top-side down.
  • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
  • The special screwdriver needed to remove the 5-point Pentalobe screws can be found here.
Image #1
Add Note Edit Step 2  ¶
  • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Image #1 Image #2
Add Note Edit Step 3 — Battery  ¶
  • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
  • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Image #1
Add Note Edit Step 4  ¶
  • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
Image #1
Add Note Edit Step 5  ¶
  • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
  • Lift the battery from its edge nearest the logic board and remove it from the upper case.
Image #1
Add Note Edit Step 6 — Left Speaker  ¶
  • Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
  • Bend the cable away from the I/O board.
Image #1
Add Note Edit Step 7  ¶
  • Use the tip of a spudger to de-route the left speaker cable from the notch cut into the edge of the I/O board.
Image #1
Add Note Edit Step 8  ¶
  • Use the flat end of a spudger to pry the left speaker connector up and out of its socket on the I/O board.
  • Pry upward from beneath the wires.
Next » « Previous
Required Tools
Spudger
$2.95 · 50+ In stock
T5 Torx Screwdriver
$6.95 · 50+ In stock
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 26 In stock
Inspection Scope
$39.95 · 39 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 18 In stock
