Image #1
Add Note Edit Step 9 — Fan  ¶
  • Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
  • Be sure you are prying up on the hinged retaining flap, not the socket itself.
Image #1
Add Note Edit Step 10  ¶
  • Remove the following three screws securing the fan to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 3.6 mm T5 Torx screw
Image #1
Add Note Edit Step 11  ¶
  • Lift the fan out of the upper case and carefully pull the fan ribbon cable out of its socket as you remove it from the Air.
Image #1
Add Note Edit Step 12 — Battery  ¶
  • Remove the following five screws securing the battery to the upper case:
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
Image #1
Add Note Edit Step 13  ¶
  • Do not touch or squeeze the six lithium polymer cells when handling the battery.
  • Lift the battery from its edge nearest the logic board and remove it from the upper case.
Image #1 Image #2
Add Note Edit Step 14 — Logic Board  ¶
  • Use the flat end of a spudger to free the adhesive loop securing to the I/O board power cable to the upper case.
  • Disconnect the I/O board by pulling the power cable away from its socket on the logic board.
  • Pull the cable parallel to the face of the logic board toward the front edge of the Air.
Image #1 Image #2
Add Note Edit Step 15  ¶
  • Use the tip of a spudger to flip up the retaining flap on the keyboard backlight ribbon cable ZIF socket.
  • Pull the keyboard backlight ribbon cable out of its socket.
Image #1 Image #2
Add Note Edit Step 16  ¶
  • Use the tip of a spudger or your fingernail to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
  • Pull the trackpad ribbon cable straight out of its socket toward the front edge of the Air.
Next » « Previous
Required Tools
T8 Torx Security Bit Screwdriver
$6.95 · 50+ In stock
Spudger
$2.95 · 50+ In stock
T5 Torx Screwdriver
Related Products
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 17 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
