Installing Mac Mini Mid 2010 Power Supply
Replace a blown power supply.
  • Add Note x
Use this guide to replace a faulty power supply. Replacing the power supply requires removal of the logic board assembly.
Sections
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Bottom Cover  ¶
  • Place your thumbs in the depressions cut into the bottom cover.
  • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
first image
Add Note Edit Step 2  ¶
  • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
  • Remove the bottom cover and set it aside.
first image
Add Note Edit Step 3 — Fan  ¶
  • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
Next » « Previous
