Installing Mac Mini Mid 2010 Bottom Cover
Removing the bottom cover.
  • Add Note x
Remove the bottom cover to access components inside your Mac mini Model A1347.
first image
thumb image 1
thumb image 2
Add Note Edit Step 1 — Bottom Cover  ¶
  • Place your thumbs in the depressions cut into the bottom cover.
  • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
first image
Add Note Edit Step 2  ¶
  • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
  • Remove the bottom cover and set it aside.
For more information, check out the Mac Mini Mid 2010 device page.
Did you successfully follow this guide?
This guide has been completed 2 times.
