first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 13  ¶
  • Hold the new drive in place and attach it to the frame using the four Phillips screws.
  • Plug the interconnect board into the new drive, making sure that all wires are in their original place.
  • Route the black thermal sensor wire back through the notch.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 14  ¶
  • Secure the thermal sensor to the new hard drive. The original adhesive on the back of the thermal sensor should hold the sensor in place.
  • Reuse the black tape from the old drive to secure the thermal sensor wire to the new drive.
  • Your newly-installed drive should look very similar to the third picture.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 15  ¶
  • Flip over the internal framework with the newly attached drive. It should look like the first picture
  • Prepare the bottom housing for connection with the internal framework by connecting the antenna cables to the Broadcom AirPort card as shown
    • Arranging the antennas as pictured will ensure a smooth connection of the two large components
  • When setting the internal framework into the bottom housing, make sure the male connector on the interconnect board finds its way into the female connector on the logic board
Next » « Previous
