Installing Mac mini Model A1283 Interconnect Board
- Author: Walter Galan
- Difficulty: Moderate
Replace your interconnect board to fix a broken hard drive/optical drive connector.
Sections
- Top Housing 5 steps
- Internal Frame 7 steps
- Interconnect Board 5 steps
- View:
- Paginated
- Full width
Edit Step 1
Top Housing
You can skip this step if you bought your putty knife from iFixit. Putty knives purchased from iFixit come with pre-ground edges.
You'll need a putty knife in order to open the case. A 1.5 inch thin putty knife will work well, but you'll want to grind the edge down. Rub the putty knife's short edge back and forth on a sheet of all purpose rough grit sandpaper (100 grit will work fine) until it attains a beveled edge.
Edit Step 2 ¶
Carefully insert a putty knife into the crevice in between the top cover and bottom housing. Start on the left side first. Push the blade down until you meet firm resistance (roughly 3/8 of an inch).
Gently enlarge the existing crevice by rotating the putty knife downward and away from the mini.
Page 1 of 6
