first image
Add Note Edit Step 19  ¶
  • Method 2: Cloning the existing hard drive.
  • The following instructions assume you will be using an external USB/FireWire enclosure for a laptop hard drive and SuperDuper! cloning software. If you’re using a different setup, your installation process may be somewhat different.
  • Install your new hard drive in the external USB/FireWire enclosure.
  • Connect the USB/FireWire enclosure to your Mac.
first image
thumb image 1
thumb image 2
Add Note Edit Step 20  ¶
  • Under the "Go" pulldown menu, select "Utilities."
  • Open "Disk Utility" from the "Utilities" window.
first image
Add Note Edit Step 21  ¶
  • Select your new hard drive from the left column in Disk Utility.
  • The correct partition type needs to be set for your new hard drive.
    • If it's a brand-new hard drive, it may have no partition listed.
    • For an Intel-based machine, you should have "GUID Partition Table" listed.
    • For a Power-PC-based machine, you should have "Apple Partition Map" listed.
  • If the incorrect partition type is listed, proceed to the next step to delete and re-create the partition. If not, proceed to step 24.
  • Warning: Deleting the partition will erase the entire contents of the partition. Make sure you have selected the new hard drive!
Next » « Previous
