Installing Mac Mini Mid 2011 Hard Drive
Prerequisite Only
Prerequisite Only
This guide is only used as a prerequisite for other guides and is not a complete or useful guide when viewed independently.
  • Add Note x
Prerequisite only.
first image
Add Note Edit Step 1 — Hard Drive  ¶
  • Use the flat end of a spudger to pry the hard drive connector up from its socket on the logic board.
first image
Add Note Edit Step 2  ¶
  • Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
first image
Add Note Edit Step 3  ¶
  • Remove the following three screws:
    • One 5.0 mm T8 Torx or 2.0 mm Hex screw (either screwdriver will work)
    • One 16.2 mm T6 Torx screw
    • One 26 mm T6 Torx standoff
Next » « Previous
