Installing Mac Mini Mid 2010 Cowling
Plastic cowling covering the heat sink.
Use this guide to remove the small molded plastic cowl used to direct cool air toward the heat sink.
Sections
Tools
Image #1 Image #2
Add Note Edit Step 1 — Bottom Cover  ¶
  • Place your thumbs in the depressions cut into the bottom cover.
  • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
Image #1
Add Note Edit Step 2  ¶
  • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
  • Remove the bottom cover and set it aside.
Image #1
Add Note Edit Step 3 — Fan  ¶
  • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
Image #1
Add Note Edit Step 4  ¶
  • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
Image #1
Add Note Edit Step 5  ¶
  • Lift the fan out of the mini for enough clearance to access its connector.
  • Carefully pull the fan cables upward to lift the fan connector up out of its socket on the logic board.
  • Remove the fan.
Image #1
Add Note Edit Step 6 — Cowling  ¶
  • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
Image #1
Add Note Edit Step 7  ¶
  • Lift the cowling from the end nearest the antenna plate.
  • Rotate the cowling away from the outer case and remove it from the mini.
Required Tools
T6 Torx Screwdriver
$4.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 13 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
Popular Products
iPhone 4S Dock Connector
$34.95 · 50+ In stock
iPhone 4S Power and Sensor Cable
$34.95 · 7 In stock
T5 Torx Screwdriver
$6.95 · 50+ In stock
Home Tech Toolkit
$24.95 · 50+ In stock
