Installing LG VX3100 Logic Board
User-Contributed Guide
  • Author: Mark Cabaj
  • Time required: 40 mintues
  • Difficulty: Difficult
BEFORE STARTING, note that this repair guide requires soldering experience!
Image #1 Image #2
  • Turn off the cellphone by pressing down on the red "END" button for 3 seconds.
  • Flip cellphone over and press up on the gray sliding mechanism towards the top of the phone. At the same time, pull on the large silver battery and it should come right off.
Image #1
Add Note Edit Step 2 — Logic Board  ¶
  • Use the T7 Torx screwdriver to remove the four screws that are in the cavity where the battery was.
Image #1 Image #2 Image #3
Add Note Edit Step 3  ¶
  • Carefully wedge the spudger around the sides of the plastic casing and pry off the back side of the phone.
  • Be careful when prying off the case. The spudger can damage the phone case.
Add Note Edit Step 4  ¶
  • Gently pry off the logic board with the spudger; notice the gold strip that connects the logic board to the rest of the phone.
  • Prying the logic board off too quickly may damage the strip.
  • Desolder the part of the gold strip that is attached to the logic board.
  • Use the spudger to carefully lift up the small latch that holds the gold strip onto the logic board.
Required Tools
Spudger
$2.95 · 50+ In stock
Soldering Station
$24.95 · 20 In stock
Lead-Free Solder
$4.95 · 50+ In stock
Desoldering Braid
T7 Torx Screwdriver
$4.95 · 4 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 6 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 47 In stock
Portable Anti-Static Mat
$24.95 · 15 In stock
Popular Products
iPhone 3G and 3GS Power Button
$4.95 · 21 In stock
Heat Gun
$24.95 · 19 In stock
Tri-wing Y1 Screwdriver
$9.95 · 50+ In stock
