Installing HTC Touch Camera Lens
Bullets!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
User-Contributed Guide
This guide will successfully lead its readers to replacing the camera on the phone.
  • Author: Sehyun
  • Time required: 15 to 30 minutes
  • Difficulty: Moderate
Warning: Always be sure you are grounded whenever handling any of the circuit or logic boards.
Image #1
Add Note Edit Step 1 — Camera Lens  ¶
  • Remove the back panel by sliding it up.
Image #1
Add Note Edit Step 2  ¶
  • Remove the battery.
Image #1
Add Note Edit Step 3  ¶
  • Remove the 4 torx-head screws in the corners of the phone using the T5 Torx Screwdriver.
Image #1 Image #2
Add Note Edit Step 4  ¶
  • Use the plastic opening tool to remove the front panel from the phone.
  • Unplug the front button cable from the inside of the phone.
Image #1
Add Note Edit Step 5  ¶
  • Unscrew the torx-head screws at the base of the LCD screen using the T5 Torx Screwdriver.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Seperate the motherboard from the black plastic casing.
  • Unplug the black and red wire from the motherboard.
  • Unplug the black and red wire from the black plastic casing.
Image #1
Add Note Edit Step 7  ¶
  • Lift the black lever next to the orange ribbon cable to remove the LCD Screen.
Image #1
Add Note Edit Step 8  ¶
  • Remove the camera lens from the motherboard using the plastic opening tool.
Required Tools
T5 Torx Screwdriver
$6.95 · 50+ In stock
Plastic Opening Tools
$2.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 19 In stock
Inspection Scope
$39.95 · 38 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
Popular Products
iPad Retina Front Panel
$94.95 · 50+ In stock
T5 Torx Screwdriver
Home Tech Toolkit
$24.95 · 50+ In stock
iFixit Guitar Picks set of 6
$6.95 · 49 In stock
iSesamo Opening Tool
$9.95 · 50+ In stock
