HP Pavilion dv6000 Hard Drive Replacement
  1. HP Pavilion dv6000 Hard Drive Replacement, Hard Drive: step 1, image 1 of 2 HP Pavilion dv6000 Hard Drive Replacement, Hard Drive: step 1, image 2 of 2
    • Remove the two screws from the hard drive shield and lift it off starting at the right side. The screws will remain in the shield.
  2. HP Pavilion dv6000 Hard Drive Replacement: step 2, image 1 of 2 HP Pavilion dv6000 Hard Drive Replacement: step 2, image 2 of 2
    • Pull the plastic tab attached to the hard drive. The hard drive lifts right out. Pull gently so you don't damage the contacts.
  3. HP Pavilion dv6000 Hard Drive Replacement: step 3, image 1 of 2 HP Pavilion dv6000 Hard Drive Replacement: step 3, image 2 of 2
    • Now you have your hard drive out!
  4. HP Pavilion dv6000 Hard Drive Replacement: step 4, image 1 of 2 HP Pavilion dv6000 Hard Drive Replacement: step 4, image 2 of 2
    • Gently pull forward the HP adapter from the top of the hard drive.
    • Insert the adapter onto the new SATA hard drive, to be replaced in the laptop.
19 other people completed this guide.
Ben Hirsch
3,826 Reputation
10 Guides authored
Cal Poly, Team 21-33, Regan Fall 2010 Member of Cal Poly, Team 21-33, Regan Fall 2010
CPSU-REGAN-F10S21G33
4 Members
12 Guides authored
2 Comments
thanks for your help
moyguens - Reply
I was scratching my head when I recvd the new hd w/out the adapter... LOL! thanks
gilaraujog - Reply
Past 24 Hours: 0
Past 7 Days: 23
Past 30 Days: 81
All Time: 41,268
