Installing GoPro HD Hero2 Rear Case
Prerequisite Only
Prerequisite Only
Please note that this guide is only a prerequisite for other guides.
GoPro HD Hero2 rear case prerequisite.
This guide is a prerequisite for removing the mini HDMI port or replacing the rear case.
Image #1
Add Note Edit Step 1 — Rear Case  ¶
  • Remove the four Phillips #00 screws securing the rear case to the rest of the device:
    • Two 5.5 mm coarse thread screws.
    • Two 4.4 mm fine thread screws.
Image #1 Image #2
Add Note Edit Step 2  ¶
  • Slide the edge of a plastic opening tool underneath the sticker on the rear cover and gently peel the sticker up.
  • Once you have enough of the sticker peeled up with the plastic opening tool, grab an edge of it with your fingers and pull it off completely.
Image #1 Image #2
Add Note Edit Step 3  ¶
  • Grasp the rear case and lift it off of the front case.
  • Do not try to completely remove the rear case yet, as it is still attached by the display port ribbon cable.
Image #1 Image #2
Add Note Edit Step 4  ¶
  • Using a plastic opening tool or your fingernail, flip up the locking tab on the SD board ribbon cable ZIF connector on the motherboard assembly.
    • Be careful that you are prying on the locking tab, and not the connector itself.
  • Use a pair of tweezers to remove the SD board ribbon cable from its connector on the motherboard.
Image #1 Image #2 Image #3
Add Note Edit Step 5  ¶
  • Lift the speaker out of the rear case with the tip of a spudger.
  • Remove the rear case.
Required Tools
Spudger
$2.95 · 50+ In stock
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Plastic Opening Tools
$6.95 · 15 In stock
Recommended Tools
Universal Drive Adapter
$29.95 · 50+ In stock
Inspection Scope
$39.95 · 17 In stock
Portable Anti-Static Mat
$24.95 · 11 In stock
Popular Products
Unibody Laptop Dual Drive
$39.95 · 3 In stock
Small Suction Cup
Heavy-duty Suction Cups (Pair)
$14.95 · 50+ In stock
Precision Tweezers Set
$4.95 · 28 In stock
Tri-wing Y1 Screwdriver
$9.95 · 50+ In stock
