Installing Garmin GPS V Logic Board
Incorrect Bullets
This guide contains bullet colors that do not match markup, or improperly-used bullet types.
User-Contributed Guide
This guide is not managed by iFixit staff.
This guide will help users replace the logic board.
- Author: Connor
- Time required: 30 minutes
- Difficulty: Moderate
- View:
- Paginated
- Full width
Edit Step 2 ¶
CAUTION: With the spudger, gently pry the back plate off the unit starting at the corners.
As you open the unit, locate the 8-pin white connector on the logic board and disconnect it. The antenna side of the device should act like a hinge as you open it.
Open the device all the way, making sure to not disconnect the brown antenna wire.
Page 1 of 2
