Installing Game Boy Micro Buttons
Step Trimmer
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
User-Contributed Guide
Inconsistent Images
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
  • Author: Jack
  • Time required: 30 minutes
  • Difficulty: Moderate
Use the following guide to replace buttons in the device.
Sections
Image #1 Image #2 Image #3
Add Note Edit Step 1 — Battery Cover  ¶
  • Remove the Phillips #00 screw on the side of the Game Boy closest to the directional pad.
  • Once the screw has been loosened, lift the cover off the back of the device.
Add Note Edit Step 2  ¶
  • With the back cover removed, the battery is connected to the device by two wires and a plastic connector.
  • Gently grab the wires.
Image #1 Image #2
Add Note Edit Step 3  ¶
  • Carefully pull the wires until the connector comes out of the device.
  • Be careful! Don't pull too hard or you may rip the wires out from the connector.
  • When putting the battery back in the device, make sure the connector is put in exactly the way it came out.
Image #1 Image #2
Add Note Edit Step 4 — Faceplate  ¶
  • Locate the two circular holes on the side of the Gameboy nearest to the directional pad.
Add Note Edit Step 5  ¶
  • Straighten the end of a paper clip and push it into each of the circular holes.
  • You may hear a faint click afterwards.
  • Use the paper clip to lever the faceplate off from the unit.
Add Note Edit Step 6 — Buttons  ¶
  • Remove two tri-wing screws on the top of the Game Boy and two more next to the volume/contrast switch.
Add Note Edit Step 7  ¶
  • Remove the three Phillips #00 screws.
  • Remove the two tri-wing screws.
Add Note Edit Step 8  ¶
  • Lift the back cover off the Game Boy.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 30 In stock
Inspection Scope
$39.95 · 40 In stock
Frictionless Ratchet
$24.95 · 49 In stock
Portable Anti-Static Mat
$24.95 · 19 In stock
Popular Products
iPad 2 Front Panel
$94.95 · 50+ In stock
$2.95 · 50+ In stock
Heavy-duty Suction Cups (Pair)
$14.95 · 50+ In stock
SIM Card Eject Tool
