Installing DualShock 3 Trigger Buttons
Replace a broken trigger button.
  • Add Note x
  • x 8
Use this guide to replace the plastic trigger buttons. The #2 trigger button has an attached internal spring.
Image #1
Add Note Edit Step 1 — Rear Cover  ¶
  • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
Image #1
Add Note Edit Step 2  ¶
  • Slightly lift the lower edge of the rear cover away from the rest of the controller.
Image #1 Image #2
Add Note Edit Step 3  ¶
  • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
  • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
  • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
Image #1
Add Note Edit Step 4 — Trigger Buttons  ¶
  • While holding the black plastic trigger retainer with one hand, pull the #2 trigger off of its axle.
Image #1 Image #2
Add Note Edit Step 5  ¶
  • When reinstalling the #2 trigger, be sure the spring is positioned as shown before popping the axle back into place.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Pull the black plastic trigger retainer slightly away from the front cover.
  • Pull the #1 button out of the front cover.
Image #1 Image #2
Add Note Edit Step 7  ¶
  • Before sliding the trigger button retainer back into the rails molded into the front cover, be sure that the cylindrical post attached to the #1 button is sitting flat on the green rubber electronic switch cover. Failure to do so may lead to problems with fit during reassembly, and may cause the controller to not recognize inputs from the #1 button during operation.
  • The trigger button assembly is properly installed when the lip on the trigger button retainer sits flat against the motherboard.
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 24 In stock
Inspection Scope
$39.95 · 39 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 17 In stock
Popular Products
54 Bit Driver Kit
$24.95 · 50+ In stock
Heavy-duty Suction Cups (Pair)
$14.95 · 50+ In stock
SIM Card Eject Tool
$2.95 · 50+ In stock
Precision Screw Extractor Set
$19.95 · 50+ In stock
