Dell Optiplex SX280 Battery Replacement
  1. Dell Optiplex SX280 Battery Replacement, Panel Cover: step 1, image 1 of 1
    • Make sure the computer is turned off, by selecting the start menu and choosing “Shut Down”.
    • Ensure all cables, speakers and other devices are unplugged and turned off before opening the computer case.
  2. Dell Optiplex SX280 Battery Replacement: step 2, image 1 of 2 Dell Optiplex SX280 Battery Replacement: step 2, image 2 of 2
    • Lay the computer on its side; you will see a blue knob.
    • Turn this knob 90 deg clockwise.
  3. Dell Optiplex SX280 Battery Replacement: step 3, image 1 of 2 Dell Optiplex SX280 Battery Replacement: step 3, image 2 of 2
    • Slide the panel case forward about 1/2 inch while knob is turned.
    • Lift panel case off computer.
  4. Dell Optiplex SX280 Battery Replacement, Hard Drive: step 4, image 1 of 2 Dell Optiplex SX280 Battery Replacement, Hard Drive: step 4, image 2 of 2
    • Unplug the blue cable that connects the hard drive to the motherboard.
  5. Dell Optiplex SX280 Battery Replacement: step 5, image 1 of 2 Dell Optiplex SX280 Battery Replacement: step 5, image 2 of 2
    • Unplug the power supply, distinguished by its red and yellow wires (yellow wire obscured from view).
  6. Dell Optiplex SX280 Battery Replacement: step 6, image 1 of 1
    • Squeeze the release tabs on either side of the hard drive.
  7. Dell Optiplex SX280 Battery Replacement: step 7, image 1 of 2 Dell Optiplex SX280 Battery Replacement: step 7, image 2 of 2
    • Slide the Hard Drive out while squeezing the tabs.
  8. Dell Optiplex SX280 Battery Replacement, Battery: step 8, image 1 of 1
    • Under the hard drive, there is a circular, silver battery connected to the motherboard.
    • Use a spudger to gently pry the battery from the motherboard.
  9. Dell Optiplex SX280 Battery Replacement: step 9, image 1 of 1
    • Lift the battery out of the motherboard.
  10. Dell Optiplex SX280 Battery Replacement: step 10, image 1 of 3 Dell Optiplex SX280 Battery Replacement: step 10, image 2 of 3 Dell Optiplex SX280 Battery Replacement: step 10, image 3 of 3
    • Upon replacement, simply push the battery into the motherboard.
10 other people completed this guide.
Tom
841 Reputation
7 Guides authored
Cal Poly, Team 22-4, Maness Fall 2010 Member of Cal Poly, Team 22-4, Maness Fall 2010
CPSU-MANESS-F10S22G4
4 Members
26 Guides authored
One Comment
that particular battery holder looked hard to get out- no pop out lever, thought i’d break it gouging it out!
neverts “itchytastyurr” ennud - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 23
All Time: 11,784
