Installing Dell Latitude D620 RAM
Missing Prerequisites
This guide is missing prerequisite guides.
User-Contributed Guide
This guide is not managed by iFixit staff.
  • Author: Miguel Wong
  • Time required: 10 minutes
  • Difficulty: Moderate
  • Add Note x
  • x 4
Guide to installing new RAM modules for the Dell Latitude D620.
Sections
Tools
first image
Add Note Edit Step 1 — Keyboard  ¶
  • Open the laptop cover all of the way.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 2  ¶
  • Locate the notch under the cover at the top of the keyboard
  • Using the spudger as a lever, lift the plastic covering
  • Carefully remove the rest of the covering from right to left
first image
Add Note Edit Step 3  ¶
  • Unscrew the top portion of the keyboard using a #00 screwdriver
first image
Add Note Edit Step 4  ¶
  • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
  • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
first image
thumb image 1
thumb image 2
Add Note Edit Step 5  ¶
  • Once keyboard is out of the case, lay it face-down on the track pad
first image
thumb image 1
thumb image 2
Add Note Edit Step 6  ¶
  • Using a small spudger, pull back on the black bar to release the blue lever
first image
Add Note Edit Step 7  ¶
  • Pull up on the metal bar connected to the socket to detach the ribbon cable
first image
thumb image 1
thumb image 2
Add Note Edit Step 8 — RAM  ¶
  • With the keyboard removed you should be able to see ram slot A
  • Place new ram into the slot making sure it is aligned
first image
Add Note Edit Step 9  ¶
  • Replace the keyboard by following the previous steps in reverse
  • Close the laptop, and flip it over onto its backside
first image
thumb image 1
thumb image 2
Add Note Edit Step 10  ¶
  • Loosen the screw that holds the RAM cover in place.
  • The screw cannot be fully removed since it is attached to the RAM cover.
first image
thumb image 1
thumb image 2
Add Note Edit Step 11  ¶
  • Insert new ram into slot B
For more information, check out the Dell Latitude D620 device page.
Did you successfully follow this guide?
This guide has been completed 4 times.
