Installing Dell Inspiron 8600 LCD
Improper Action
Improper Action
This guide contains images that improperly convey how to perform a specific action.
Incorrect Tools
Incorrect Tools
This guide contains steps that use incorrect tools in images and/or text.
User-Contributed Guide
This guide is not managed by iFixit staff.
Follow this guide to replace the LCD display.
  • Author: Perry
  • Time required: 20-40 minutes
  • Difficulty: Moderate
  • Add Note x
Follow this guide to remove the LCD Display.
Sections
Tools
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — Hinge Cover  ¶
  • Insert a spludger into the notch at the far left side of the top blue panel and pry hinge cover off.
  • Note: You may need to pry the other side off by inserting the spludger between the hinge and the top cover.
  • Be careful of wire attached to underside of the hinge cover.
first image
Add Note Edit Step 2  ¶
  • Pull the small black tab on the right hand side of the laptop.
  • The hinge cover has now been removed.
first image
thumb image 1
thumb image 2
Add Note Edit Step 3 — Display Module  ¶
  • Flip the laptop over and remove indicated screws.
  • Flip the laptop back over.
  • Find the two places where the display module is attached to the base of the computer.
first image
Add Note Edit Step 4  ¶
  • Disconnect the video card from the display module by gently lifting upwards on the black tab.
first image
thumb image 1
thumb image 2
Add Note Edit Step 5  ¶
  • Lift the display module directly upwards.
first image
Add Note Edit Step 6  ¶
  • The display module has been removed.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 7 — LCD  ¶
  • First, remove the plastic tabs that are covering the interior screws.
  • After removing the tabs, remove the interior screws using a #1 Philips Screwdriver.
  • Note there are 8 tabs and 8 screws in total.
first image
Add Note Edit Step 8  ¶
  • Now that the screws are removed, press the plastic casing inward to loosen the case. Then remove the plastic case from the monitor unit.
first image
Add Note Edit Step 9  ¶
  • Using a Philips #1 screwdriver remove the screws holding the LCD in place.
  • Note there are 8 screws in total for this step, 4 on each side of the unit.
first image
Add Note Edit Step 10  ¶
  • Remove the broken LCD unit, and replace with new unit.
For more information, check out the Dell Inspiron 8600 device page.
Did you successfully follow this guide?
This guide has been completed 1 time.
