Page 1 of 1
Installing Dell Inspiron 1525 S-Video Board
Replace the S-Video Board in a Dell Inspiron 1525.
- Author: Phillip Takahashi
- Time required: 45 to 60 minutes
- Difficulty: Moderate
Use this guide to help you replace the S-Video Board in a Dell Inspiron 1525.
Sections
- Battery 3 steps
- Central Control Cover 3 steps
- Keyboard 2 steps
- Hard Drive 1 step
- Optical Drive 1 step
- Bottom Cover 1 step
- Display Assembly 6 steps
- Upper Case 5 steps
- ExpressCard Cage 1 step
Sections (continued)
- Heat Sink 2 steps
- Motherboard 4 steps
- S-Video Board 1 step
Tools
Relevant parts
- View:
- Paginated
- Full width
Edit
Step 7
Keyboard
Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
Gently slide the keyboard towards the display until the tabs on its front side are free.
Do not force the keyboard too far forward or attempt to remove it yet, as there is still a ribbon cable connected to it.
Edit
Step 23
ExpressCard Cage
Eject your ExpressCard or ExpressCard dust shield if you want to transfer it to the new ExpressCard cage. Eject the card by pressing it in until it clicks, releasing it, then sliding it out.
Remove the 3.80 mm Phillips #1 screw securing the ExpressCard cage.
Remove the two 3.70 mm Phillips #1 screws securing the ExpressCard cage.
Lift the ExpressCard cage out of its connector.
Edit
Step 24
Heat Sink
Loosen the five #1 Phillips screws securing the heat sink and clean it with compressed air
These screws are attached to the heat sink assembly.
Gently lift the heat sink from side indicated in the picture.
The heat sink may feel like it is glued to the chips because of the thermal paste. Gently wiggle the heat sink back and forth to help break it free.
Be sure to thoroughly clean off the old thermal paste and apply new thermal paste before reinstalling the heat sink. Follow our thermal paste application guide for detailed instructions.
Edit
Step 25
Now to clean the internal fan in the computer if nessacary
To do this, spray canned air into the fan by putting the straw into the holes on the case and blow it out
Expect to pay a fair and/or a ID for canned air because kids get high off of it, unless you find a place there it is cheap and does not ID
This guide has been completed 0 times.
Page 1 of 1
