Installing Dell Inspiron 1525 Hard Drive Tray
Replace the hard drive tray in a Dell Inspiron 1525.
  • Add Note x
Use this guide to help you replace the hard drive tray in a Dell Inspiron 1525.
Sections
Tools
first image
  • Locate the battery release switch on the bottom of the laptop.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Slide the battery release switch away from the lock symbol until you hear the battery click.
  • Slide the battery towards the back of the laptop until it comes free.
first image
Add Note Edit Step 3  ¶
  • Remove the cover that has the heatsink by unscrewing 9 screws highlighted in red
  • These screws are all captive except the screw with a lock by it
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 4 — Hard Drive  ¶
  • Remove the two 3.60 mm #1 Phillips screws securing the hard drive and hard drive tray.
  • Slide the hard drive and hard drive tray out of the laptop.
first image
thumb image 1
thumb image 2
Add Note Edit Step 5 — Hard Drive Tray  ¶
  • Remove the two 3.55 mm Phillips #1 screws securing the hard drive to the hard drive tray.
    • There is 1 screw on each side of the tray.
  • Remove the hard drive from the tray.
For more information, check out the Dell Inspiron 1525 device page.
Did you successfully follow this guide?
This guide has been completed 0 times.
