Installing Dell Inspiron 1525 ExpressCard Cage
Replace the ExpressCard Cage in a Dell Inspiron 1525.
  • Add Note x
Use this guide to help you replace the ExpressCard Cage in a Dell Inspiron 1525.
Sections
first image
  • Locate the battery release switch on the bottom of the laptop.
first image
thumb image 1
thumb image 2
Add Note Edit Step 2  ¶
  • Slide the battery release switch away from the lock symbol until you hear the battery click.
  • Slide the battery towards the back of the laptop until it comes free.
first image
Add Note Edit Step 3  ¶
  • Remove the cover that has the heatsink by unscrewing 9 screws highlighted in red
  • These screws are all captive except the screw with a lock by it
first image
Add Note Edit Step 4 — Central Control Cover  ¶
  • Remove the two 4.00 mm Phillips #1 screws from the battery tray.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 5  ¶
  • Insert the flat end of a spudger into the slot on the right side of the central control cover and pry it up.
  • Carefully pull the central control cover up along its edges.
    • Do not attempt to completely remove the cover, as it is still attached via a ribbon cable.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 6  ¶
  • Peel back the silver tape securing the ribbon cable to the cover.
  • Pull the small brown latch on the ribbon cable connector out.
  • Disconnect the ribbon cable to completely free the central control cover.
first image
thumb image 1
thumb image 2
Add Note Edit Step 7 — Keyboard  ¶
  • Remove the two 5.75 mm Phillips #1 screws securing the keyboard to the laptop.
  • Gently slide the keyboard towards the display until the tabs on its front side are free.
    • Do not force the keyboard too far forward or attempt to remove it yet, as there is still a ribbon cable connected to it.
first image
thumb image 1
thumb image 2
Add Note Edit Step 8  ¶
  • Use a spudger to gently lift the ribbon cable retaining flap.
  • Disconnect the ribbon cable.
  • Shift the keyboard sideways enough to free one side from it's retaining tab. Then lift the keyboard away from the laptop.
first image
thumb image 1
thumb image 2
Add Note Edit Step 9 — Bottom Cover  ¶
  • Remove the eight 4.80 mm Phillips #1 screws securing the bottom panel.
  • Remove the bottom panel.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 10 — Display Assembly  ¶
  • Disconnect the five antennas from their respective cards.
  • De-route the antennas from their routing retainers.
first image
Add Note Edit Step 11  ¶
  • Remove the two 5.70 mm Phillips #1 screws securing the display assembly to the bottom case half.
    • The screw holes will be denoted by an embossed "D" by the hole.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 12  ¶
  • Use the flat end of a spudger to push the camera connector out of its socket. Alternate pushing on either side to evenly remove the connector.
  • Carefully release the connector from its retaining tabs.
first image
thumb image 1
thumb image 2
Add Note Edit Step 13  ¶
  • Push the antenna wires up through their hole in the bottom case half.
  • Release the antennas from their retaining tabs on the upper case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 14  ¶
  • Disconnect the flat LCD ribbon cable by pulling it up by its flap.
  • Free the ribbon cable from its retaining clips.
first image
Add Note Edit Step 15  ¶
  • Remove the four 3.45 mm Phillips #1 screws securing the display assembly to the laptop chassis.
    • Support the display assembly as you remove these screws to prevent damage to the screw and hole threads.
  • Remove the display assembly from the laptop.
first image
thumb image 1
thumb image 2
Add Note Edit Step 16 — Upper Case  ¶
  • Remove the nine 5.75 mm Phillips #1 screws on the bottom side of the laptop.
  • Remove the two 5.70 mm Phillips #1 screws on the top side of the laptop.
first image
thumb image 1
thumb image 2
Add Note Edit Step 17  ¶
  • Use a spudger to pull the touch pad connector latch towards the ribbon cable.
  • Pull the ribbon cable out of the connector.
first image
thumb image 1
thumb image 2
Add Note Edit Step 18  ¶
  • Use a spudger to pull the device status LED connector latch towards the ribbon cable.
  • Disconnect the device status LED ribbon cable.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 19  ¶
  • Release the ribbon cable in the upper left corner of the laptop from its retaining tabs.
  • Use a spudger to unplug the speaker connector at the top center of the laptop.
  • De-route the speaker wires from their retaining tabs.
first image
thumb image 1
thumb image 2
Add Note Edit Step 20  ¶
  • Use the flat end of a spudger to begin lifting the upper case at its front edge.
  • Lift the front edge of the case up until it comes free.
    • Work slowly and be sure not to get any cables caught in the upper case holes and guides.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 21 — ExpressCard Cage  ¶
  • Eject your ExpressCard or ExpressCard dust shield if you want to transfer it to the new ExpressCard cage. Eject the card by pressing it in until it clicks, releasing it, then sliding it out.
  • Remove the 3.80 mm Phillips #1 screw securing the ExpressCard cage.
  • Remove the two 3.70 mm Phillips #1 screws securing the ExpressCard cage.
  • Lift the ExpressCard cage out of its connector.
For more information, check out the Dell Inspiron 1525 device page.
Did you successfully follow this guide?
This guide has been completed 0 times.
