Page 1 of 1
Installing Dell Inspiron 1525 CPU
Replace the CPU in a Dell Inspiron 1525.
- Author: Phillip Takahashi
- Time required: 15 to 20 minutes
- Difficulty: Moderate
Use this guide to replace the CPU in a Dell Inspiron 1525.
Sections
- Battery 3 steps
- Bottom Cover 1 step
- Heat Sink 2 steps
- CPU 1 step
- View:
- Paginated
- Full width
Edit Step 5
Heat Sink
Loosen the five #1 Phillips screws securing the heat sink and clean it with compressed air
These screws are attached to the heat sink assembly.
Gently lift the heat sink from side indicated in the picture.
The heat sink may feel like it is glued to the chips because of the thermal paste. Gently wiggle the heat sink back and forth to help break it free.
Be sure to thoroughly clean off the old thermal paste and apply new thermal paste before reinstalling the heat sink. Follow our thermal paste application guide for detailed instructions.
Edit Step 6 ¶
Now to clean the internal fan in the computer if nessacary
To do this, spray canned air into the fan by putting the straw into the holes on the case and blow it out
Expect to pay a fair and/or a ID for canned air because kids get high off of it, unless you find a place there it is cheap and does not ID
Edit Step 7
CPU
Use a small flathead screwdriver to turn the ZIF-socket cam screw counterclockwise until it can't be turned anymore.
Lift the CPU out of its socket, being careful not to bend its pins.
Processor orientation can be determined by matching the corner of the processor with a small triangle to the corner of the pink module with a small triangle.
Don't forget to apply thermal paste to the new processor. Also clean and apply fresh thermal paste to the video processor. Follow our thermal paste application guide for detailed instructions.
This guide has been completed 0 times.
Page 1 of 1
