Installing Apple TV 1st Generation Logic Board
User-Contributed Guide
This guide is not managed by iFixit staff.
Replace your Apple TV's 1st Generation logic board.
  • Add Note x
  • x 3
Sections
first image
Add Note Edit Step 1 — Lower Case  ¶
  • Flip the Apple TV over so that the bottom of the unit is facing up.
  • You need to remove the rubber base to get access to the screws.
  • Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
  • The rubber base will be hot after heating, take extreme while proceeding.
  • While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
  • Repeat the procedure described above until the rubber base has been completely removed.
first image
Add Note Edit Step 2  ¶
  • Remove the four T10 Torx screws securing the lower case to the upper case.
first image
Add Note Edit Step 3  ¶
  • Lift and remove the lower case from the upper case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Carefully pull the hard drive data cable straight up from its socket on the logic board.
  • During reassembly, make sure the hard drive data cable is firmly seated in its socket on the logic board. Otherwise, during boot-up you will see a flashing question mark "?".
first image
Add Note Edit Step 5 — Fan  ¶
  • The fan is held in place by three rubber posts.
  • Using a pair of tweezers, squeeze the top of each post and push the post down into the hole. Repeat for all three posts.
  • During reinstallation, it helps to lubricate the rubber posts. Try weaving a string through the holes in the posts to pull them up through the mounting points.
  • Do not excessively pull on the posts, as they may rip.
first image
Add Note Edit Step 6  ¶
  • Using a pair of tweezers, pull the fan connector straight up from its socket on the logic board.
  • Lift and remove the fan out of the upper case.
first image
Add Note Edit Step 7 — AirPort Card  ¶
  • Pry the AirPort antenna cables straight up from their sockets on the logic board.
first image
Add Note Edit Step 8  ¶
  • Remove the single T8 Torx screw securing the AirPort card to the logic board.
first image
Add Note Edit Step 9  ¶
  • Cautiously lift the AirPort card and pull it straight away slide from its socket on the logic board.
first image
Add Note Edit Step 10 — Power Supply  ¶
  • Disconnect the power cable straight up from its socket on the logic board.
  • There is a release tab that must be pushed inwards in conjunction to release the power cable
  • Make sure to pull the connector straight up from its socket and not toward the face of the logic board.
first image
Add Note Edit Step 11  ¶
  • Remove the following three screws securing the power supply to the upper case:
    • One 4.8 mm T8 Torx screw
    • Two 5.8 mm T8 Torx screws
first image
thumb image 1
thumb image 2
Add Note Edit Step 12  ¶
  • Use your finger to push and dislodge the DC power connector inwards, towards the power supply.
  • This should pop out easily.
first image
Add Note Edit Step 13  ¶
  • Power supply remains.
first image
Add Note Edit Step 14 — Logic Board  ¶
  • Remove the T8 Torx screw securing the metal shield to the case.
  • In order to remove the T8 screw, you must insert the screwdriver through the access hole in the metal shield, located near the PRAM battery.
first image
thumb image 1
thumb image 2
Add Note Edit Step 15  ¶
  • Remove the T20 screw securing the metal shield to the case, located near the digital audio port.
  • Lift and remove the metal shield away from the upper case of the Apple TV.
first image
Add Note Edit Step 16  ¶
  • Use a pair of tweezers to pull the IR cable straight away from its socket on the logic board.
  • Make sure to pull the connector parallel to the face of the logic board, not straight up from its socket.
first image
Add Note Edit Step 17  ¶
  • Lift the left edge of the logic board (nearest the PRAM battery) upwards and slide it out of the case, away from the ports.
  • Be careful to not damage the ports when sliding the logic board out of case.
  • Logic board remains.
For more information, check out the Apple TV 1st Generation device page.
Did you successfully follow this guide?
This guide has been completed 3 times.
