Page 1 of 1
Installing Apple TV 1st Generation Hard Drive Replacement
User-Contributed Guide
This guide is not managed by iFixit staff.
Replace the hard drive in your Apple TV 1st Generation.
- Author: Walter Galan
- Difficulty: Moderate
- View:
- Paginated
- Full width
Edit Step 1
Lower Case
Flip the Apple TV over so that the bottom of the unit is facing up.
You need to remove the rubber base to get access to the screws.
Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
The rubber base will be hot after heating, take extreme while proceeding.
While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
Repeat the procedure described above until the rubber base has been completely removed.
Edit Step 6 ¶
Peel and remove the hard drive up off the lower case.
The hard drive is held on to the lower case with mild adhesive.
Disconnect the hard drive data cable from its socket on the hard drive.
If you are replacing your hard drive, ensure to transfer the hard drive data cable to your new hard drive.
Hard drive remains.
This guide has been completed 7 times.
Page 1 of 1
