Installing Apple TV 1st Generation Fan
User-Contributed Guide
This guide is not managed by iFixit staff.
Replace the fan in your Apple TV 1st Generation.
  • Author: ropel
  • Difficulty: Moderate
  • Add Note x
Sections
Tools
first image
Add Note Edit Step 1 — Lower Case  ¶
  • Flip the Apple TV over so that the bottom of the unit is facing up.
  • You need to remove the rubber base to get access to the screws.
  • Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
  • The rubber base will be hot after heating, take extreme while proceeding.
  • While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
  • Repeat the procedure described above until the rubber base has been completely removed.
first image
Add Note Edit Step 2  ¶
  • Remove the four T10 Torx screws securing the lower case to the upper case.
first image
Add Note Edit Step 3  ¶
  • Lift and remove the lower case from the upper case.
first image
thumb image 1
thumb image 2
Add Note Edit Step 4  ¶
  • Carefully pull the hard drive data cable straight up from its socket on the logic board.
  • During reassembly, make sure the hard drive data cable is firmly seated in its socket on the logic board. Otherwise, during boot-up you will see a flashing question mark "?".
first image
Add Note Edit Step 5 — Fan  ¶
  • The fan is held in place by three rubber posts.
  • Using a pair of tweezers, squeeze the top of each post and push the post down into the hole. Repeat for all three posts.
  • During reinstallation, it helps to lubricate the rubber posts. Try weaving a string through the holes in the posts to pull them up through the mounting points.
  • Do not excessively pull on the posts, as they may rip.
first image
Add Note Edit Step 6  ¶
  • Using a pair of tweezers, pull the fan connector straight up from its socket on the logic board.
  • Lift and remove the fan out of the upper case.
For more information, check out the Apple TV 1st Generation device page.
Did you successfully follow this guide?
This guide has been completed 2 times.
