Page 1 of 1
Installing Apple TV 1st Generation AirPort Card
User-Contributed Guide
This guide is not managed by iFixit staff.
Replace the AirPort card in your Apple TV 1st Generation.
- Author: ropel
- Difficulty: Moderate
- View:
- Paginated
- Full width
Edit Step 1
Lower Case
Flip the Apple TV over so that the bottom of the unit is facing up.
You need to remove the rubber base to get access to the screws.
Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
The rubber base will be hot after heating, take extreme while proceeding.
While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
Repeat the procedure described above until the rubber base has been completely removed.
This guide has been completed 4 times.
Page 1 of 1
