Installing Apple Powerbook 5300 Monitor
Action Shots
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Inconsistent Images
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
User-Contributed Guide
Missed a Step
Missed a Step
Oops! This guide is currently missing some important steps.
Bullets!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Confusing Text
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Incorrect Tools
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Markup Mishap
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
How to remove and replace the monitor on the Apple Powerbook 5300
  • Author: Scott
  • Difficulty: Moderate
Sections
Image #1
  • With laptop facing towards you, press in on the battery removal latch (located on the right side of the front panel). Pull to the right on the battery, and it will slide out.
Image #1
Add Note Edit Step 2 — Keyboard  ¶
  • Remove the three T8 torx screws from the bottom of the laptop.
Image #1
Add Note Edit Step 3  ¶
  • Turn the laptop back over, open the lid, and lift the keyboard up.
  • The keyboard is connected by a ribbon cable, do not pull hard or too far.
Image #1
Add Note Edit Step 4  ¶
  • Turn the keyboard over, and pull up on the ribbon cable to disconnect it from the laptop. The cable can be just pulled straight up and out of its connector on the logic board.
Image #1
Add Note Edit Step 5 — Monitor  ¶
  • Remove side panels by pulling up, and towards the rear of the laptop. This will reveal two torx #8 screws that need to be taken out.
Image #1 Image #2
Add Note Edit Step 6  ¶
  • Disconnect the ribbon cable from the logic board by pulling it up and out of its connector. Note that the cable is twisted around the monitor hinge, so do not pull straight up. Make sure to unravel the cable from the hinge first.
Image #1 Image #2
Add Note Edit Step 7  ¶
  • Use a pin to pry up the Powerbook 5300 and Macintosh logos to reveal two torx #8 screws. Remove these screws.
Image #1
Add Note Edit Step 8  ¶
  • Use a wedge tool to pry open the two halves of the monitor assembly. Lift the top half away from the bottom half.
Next » « Previous
Popular Products
iPhone 4S Rear Glass Panel
$44.95 · 50+ In stock
Heat Gun
$24.95 · 21 In stock
Tri-point Y0 Screwdriver
$9.95 · 23 In stock
