Installing Kindle Fire Battery
Replace the battery in an Amazon Kindle Fire
  • Add Note x
Use this guide to help you replace the battery in the Amazon Kindle Fire.
Sections
Tools
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 1 — Back Case  ¶
  • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
  • Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
  • If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
first image
Add Note Edit Step 2  ¶
  • Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
first image
thumb image 1
thumb image 2
thumb image 3
Add Note Edit Step 3 — Battery  ¶
  • Fit the tip of the plastic opening tool between the right battery cell and the Kindle Fire's frame.
  • Lever the battery up and work the plastic opening tool down along its edge to release the glue securing it to the frame.
first image
Add Note Edit Step 4  ¶
  • Repeat the process from the previous step to free the left battery cell.
first image
thumb image 1
thumb image 2
Add Note Edit Step 5  ¶
  • Lift the back of the battery up to relieve any tension in the battery connector and simultaneously use a spudger to push the battery connector out of its socket.
  • Pull the battery out of the Kindle Fire.
For more information, check out the Kindle Fire device page.
Did you successfully follow this guide?
This guide has been completed 0 times.
