Page 1 of 1
Installing Kindle Fire Back Case
Remove the back case from your Kindle Fire.
- Author: Phillip Takahashi
- Time required: 5 to 10 minutes
- Difficulty: Easy
Remove the back case from your Kindle Fire to access its internal components.
- View:
- Paginated
- Full width
Edit Step 1
Back Case
Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
This guide has been completed 0 times.
Page 1 of 1
