Installing Acer Aspire One ZG5 Motherboard
User-Contributed Guide
Grammar Police
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Confusing Text
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Markup Mishap
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
This guide will show you how to install a new motherboard.
  • Author: Doug Gallatin
  • Time required: 20 minutes
  • Difficulty: Moderate
  • Add Note x
  • x 13
You will remove several cables, screws, and finally the motherboard. This opens up the device in order to repair practically everything.
Image #1
  • Turn the netbook upside down with the battery at the top, away from you.
Image #1
Add Note Edit Step 2  ¶
  • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
Image #1
Add Note Edit Step 3  ¶
  • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
Image #1
Add Note Edit Step 4 — Wireless Card  ¶
  • Remove the two screws on the small panel towards the top left of the netbook with the Phillips #0 screwdriver.
    • These screws are built into the panel so they won't come out freely.
Image #1
Add Note Edit Step 5  ¶
  • Gently lift and remove the plate from the netbook.
Image #1
Add Note Edit Step 6  ¶
  • Disconnect the two antenna wires attached to the left side of the wireless card.
Image #1
Add Note Edit Step 7  ¶
  • Remove the 3.9mm screw located on the bottom left of the wireless card with Phillips #1 screwdriver.
Image #1
Add Note Edit Step 8  ¶
  • Gently lift the wireless card from its housing starting with the side where the antenna wires were.
Next » « Previous
Required Tools
Phillips #00 Screwdriver
$4.95 · 50+ In stock
Spudger
$2.95 · 50+ In stock
Phillips #1 Screwdriver
$4.95 · 27 In stock
Recommended Tools
Universal Drive Adaptor
$29.95 · 50+ In stock
iFixit Lock Pick Set
$29.95 · 14 In stock
Inspection Scope
$39.95 · 37 In stock
Frictionless Ratchet
$24.95 · 48 In stock
Portable Anti-Static Mat
$24.95 · 16 In stock
Popular Products
Small Suction Cup
54 Bit Driver Kit
$24.95 · 50+ In stock
T5 Torx Screwdriver
$6.95 · 50+ In stock
