Acer Aspire One ZG5 Keyboard Replacement
  1. Acer Aspire One ZG5 Keyboard Replacement, Battery: step 1, image 1 of 1
    • Turn the netbook upside down with the battery at the top, facing away from you.
  2. Acer Aspire One ZG5 Keyboard Replacement: step 2, image 1 of 1
    • Unlock the battery by sliding the switch located near the left hinge to the left "unlocked" position.
  3. Acer Aspire One ZG5 Keyboard Replacement: step 3, image 1 of 1
    • Slide the latch located on the opposite hinge from the lock while pushing the battery up.
  4. Acer Aspire One ZG5 Keyboard Replacement, Keyboard: step 4, image 1 of 1
    • Turn the netbook over and open the display so that the keyboard is facing you.
  5. Acer Aspire One ZG5 Keyboard Replacement: step 5, image 1 of 3 Acer Aspire One ZG5 Keyboard Replacement: step 5, image 2 of 3 Acer Aspire One ZG5 Keyboard Replacement: step 5, image 3 of 3
    • There are three tabs located on the top of the keyboard.
    • Start with the spudger pointing towards the display and pry up to push each tab off the keyboard.
    • As you move to the next tab, ensure the previous tab doesn't reset itself.
  6. Acer Aspire One ZG5 Keyboard Replacement: step 6, image 1 of 2 Acer Aspire One ZG5 Keyboard Replacement: step 6, image 2 of 2
    • Lift top of keyboard up. If it doesn't lift easily, there may be tabs on the sides - use the tool to ease them aside and/or shift the keyboard from side to side.
    • There is a short ribbon cable connecting the keyboard to the netbook.
  7. Acer Aspire One ZG5 Keyboard Replacement: step 7, image 1 of 2 Acer Aspire One ZG5 Keyboard Replacement: step 7, image 2 of 2
    • Disconnect the ribbon by lifting the black plastic hinge and removing the clear blue cable.
12 other people completed this guide.
Doug Gallatin
6,337 Reputation
10 Guides authored
Cal Poly, Team 7-49, Amido Fall 2010 Member of Cal Poly, Team 7-49, Amido Fall 2010
CPSU-AMIDO-F10S7G49
5 Members
27 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 18
All Time: 24,617
